8 members (Ridgeback, GMCJammer51, Biermann, Danielbolt, sron48, GIJOE298, Phak1, DadsFirstPickup),
111
Mod | | | Forums66 Topics128,154 Posts1,056,835 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 35 Junior Member | | Junior Member Joined: Dec 2005 Posts: 35 | Hello wounder if someone might know were to look for the vin on a 40 suburban, I have the tag for the fire wall which says Model # AC101 Serial #12225 would that be the title vin # or did they use the engine serial #.Thanks for the help. Chris | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | The VIN number originally would have been either the model/serial number or the engine serial number depending on where it was first registered. If the title was ever lost, the new VIN number may not be anywhere on the vehicle. Your GMC frame will also have a seriel number that should match the ID tag on the firewall. That serial number is located on the passenger side of the frame in front of the front axle. | | | | | Joined: Dec 2005 Posts: 35 Junior Member | | Junior Member Joined: Dec 2005 Posts: 35 | Would the frame number be on the side or top of the frame. Thanks Chris | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Vin is on the side. Turn the wheel to the right, with a little cleaning you should find your numbers just forward of the axle. The frame numbers should be identical to your ID plate. | | |
