5 members (TooMany2count, 1955 1 Series, homer52, UtahYork, J Lucas), 90 guests, and 3 robots.
Topics128,087
Posts1,056,377
Members48,442
Junior Member
Junior Member
Hello wounder if someone might know were to look for the vin on a 40 suburban, I have the tag for the fire wall which says
Model # AC101 Serial #12225
would that be the title vin # or did they use the engine serial #.Thanks for the help. Chris
The VIN number originally would have been either the model/serial number or the engine serial number depending on where it was first registered.
If the title was ever lost, the new VIN number may not be anywhere on the vehicle.
Your GMC frame will also have a seriel number that should match the ID tag on the firewall. That serial number is located on the passenger side of the frame in front of the front axle.
Junior Member
Junior Member
Would the frame number be on the side or top of the frame. Thanks Chris
Vin is on the side. Turn the wheel to the right, with a little cleaning you should find your numbers just forward of the axle. The frame numbers should be identical to your ID plate.
