1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#244455 07/08/2005 10:45 PM
Driving down the road in my Panel is like living in a large oil can. Some times it's like someone is beating on the outside of a 55 gal drum with your head inside. All of the roof ribs are pretty close to each other as far as bend radius. What was or what can be put between the ribs and the roof to quiet this noise ?? I don't think the roof was fastened in any way to the ribs. What's left of my hearing thanks you.
Mike
In loving Honor of
PFC Benjamin Gandalf Young
30 March 1988 - 27 May 2007
Sometime I wonder, Who you'd be today
www.BENS58.COM
#244456 07/08/2005 10:56 PM
actually there was an asphalty fibre material glued to the roof metal from the factory - you don't want to shim between the roof panel and the headliner bows, you want to get some of the peel n seal folks have discussed here and stick it to the roof in sections between the bows, then if you can afford it someday, get a headliner made for the truck - what's happening is called 'drumming' and happens on all large 'un-ribbed' panels like the panel truck roofs, even the doors
#244457 07/09/2005 4:18 AM
Junior Member
Junior Member
Quote
Watch out for that original " asphalt padding ".
It is loaded with asbestos.
#244458 07/09/2005 4:43 AM
what's the source for that Tex? GM used asbestos where tar impregnated paper would do? brake shoes and clutch linings maybe, but vibration damping material? it's not a high temperature or friction application - even the inside firewall insulation is just fiber
#244459 07/09/2005 10:46 AM
I think that this must be the same material used in the back of the cabs. It seems to be very close to roofing felt, maybe twice as thick.
1951 1 Ton Completed
#244460 07/09/2005 2:29 PM
I would try "gluing" the roof sheet metal to the ribs first with some body sealer. Kind of like how they do to the underside of the more modern car hoods, then tie it all together with the silencing material.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#244461 07/11/2005 2:09 AM
I like Scott's idea with the seam sealer. I also took "owens corning 703" and glued it between the ribs. This is the stuff we use to control sound in recording studios. I covered the 703 pieces with a trash bag glued on with 3M spray aghesive. Then I glued the panels to the roof with construction adhesive. I plan on constructing a headliner soon to cover the whole thing up. It has made a huge difference in the volume.
1959 Chevy Apache-Suburban
5.3, 4L60e, Camaro Subframe, enjoy doing the work ourselves!
More on Hotrodders
Driving the past into the future.
#244462 07/11/2005 11:36 PM
THANKS GUYS FOR THE IDEAS. I ENDED UP USING FOAM RUBBER WITH STICKY ON ONE SIDE. I HAD SOME LEFT OVER FROM A JOB WHERE WE INSTALLED A NEW ROOF TOP UNIT FOR A COMMERCIAL JOB. IT QUIETED DOWN THE DRUM CONSIDERABLY. NOW I CAN TURN THE STEREO UP AND DRIVE THE YOUNGSTERS NUTS PLAYING OLDIES AND NOT HAVE TO WORRY WHEN THE NEXT ROOF BOOM WILL OCCUR. THANKS AGAIN.
MIKE
In loving Honor of
www.BENS58.COM
#244463 07/15/2005 11:29 PM
Quote
Mike
deuter
1958 GMC Panel
[http://www.stovebolt.com/gallery/hardy_paul_1958.htm]1956 GMC Pickup[/URL]
#244464 07/15/2005 11:30 PM
Hello,
I'm new to stovebolt and I'm trying to figure out how to start a new post...Can anyone help...deuter
deuter
1958 GMC Panel
#244465 07/16/2005 2:44 AM
Dueter welcome to the Stovebolt. There is a graphic 'post new topic' about one inch down from the top of this window.
