1 members (78buckshot), 64 guests, and 3 robots.
Topics128,089
Posts1,056,004
Members48,430
#244343 06/06/2005 10:32 PM
I
I Offline
My son and I are starting our 57 panel Project. We bought a 77 K5 Blazer for the frame and drive line. (Yeah its a 350... and I know you don't all approve) I don't have a problem lengthening the wheel base 7-1/2" but the front tread width is about 6" wider on the K5. (The rear should be fine.)
I noticed that the rims on the K5 are very deep... (I don't know how to explain it) the mounting surface is such that the tires are off center to the outside.
Are there any stock rims readily available to change the offset and narrow the tread width?
Also, will it look strange with different rims on the front than the rear?
I tried posting this in the general truck forum but haven't gotten any replies... I really need help figuring this out.
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#244344 06/08/2005 11:59 AM
You can use later model Chevy 4X4 wheels i.e. 88up as they are 6 lug and also they don't have as much off set, I believe there is even a little negative offset to them. If you have'nt gotten too far into it you could try getting a frame from a later model extended cab 4X4 so you wouldn't have to extend it. As far as different rims, I would run the same ones, your only other choice would be to run a narrower front axle like a Jeep or Bronco. Later
Dave
Even a blind squirrel gets a nut sometimes!
#244345 06/09/2005 4:23 PM
I
I Offline
Thanks Bowtie70ss,
I already got the Blazer so the path is already paved... (although it may be a little bumpy) I will keep my eyes out for rims with shallower offset. I would rather avoid changing axles because I dont want to end up with a POS with different ratios.
Inky,
'48 1-1/2 ton Dump
'57 Chevy Panel
#244346 06/10/2005 5:26 AM
Hub caps can hide the difference between the wheels.
The axle can be narrowed also.
#244347 06/10/2005 11:23 PM
I
I Offline
OldSub,
I wouldn't know where to start with narrowing the axles. I'm sure I could figure it out though. I would just need to obtain an assembly drawing so I could figure out what all needs to be shorter. (have a good machine shop at my disposal)
If anyone knows where I could get a DWG. I'd consider it.
Inky,
'48 1-1/2 ton Dump
'57 Chevy Panel
#244348 06/11/2005 6:29 AM
I'd try some different wheels on it and see if there's anything that will make it look right.If that doesn't work,see if a front end from a 67-72 is any closer to the width you want, find out what ratio you have;it shouldn't be too hard to find one with the right ratio.
I also read that Toyota 4X4 axles are the right width,and as durable,if you don't drive like a complete idiot.
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#244349 06/12/2005 2:55 AM
I know a narrow-track Dana 44 from a narrow-track Wagoneer is the right width for an AD truck - how much wider is a TF? Maybe the wide-track Wagoneer axle would fit. Then you could switch the knuckles with the ones from the K5 axle and maintain all Chevy steering parts.
1954 GMC De Luxe COE
#244350 06/12/2005 2:54 PM
Toyota 4X4 rims are the same i have them on my 1989 3/4 ton 4x4 and my 1942 truck has a set on it also
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
