7 members (Bill Hanlon, Southerntruck, Bungeemaster, 2-Ton, Pre '68 Dave, TUTS 59, 1 invisible),
278
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,288 Posts1,058,566 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 22 | Does anyone have a template on the placement of the trim I have a set that I want to install on my suburban just don't know the location.Any help is appreciated. :confused: Thanks | | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | I think the '47-'54 Factory Assembly Manual reprint has install instructions for the trim, which was a RPO for the panel truck only. | | | | | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | Yes, it's shown in the assembly manual. | | | | | Joined: Mar 2004 Posts: 44 Member | | Member Joined: Mar 2004 Posts: 44 | I can measure for you once I take off my trim but, it'll be a while before I make it to that. 1954 Chevy 3100 Panel Truck 2004 GMC Yukon 2002 Chevy 1500 4X4 "Those who expect to reap the blessings of freedom, must, like men, undergo the fatigues of supporting it." Thomas Paine, The American Crisis, No. 4, September 11, 1777
| | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | You know the trim placement turned out to be pretty much a "go ..no go " proposition. If your fenders are true, the trim only lies flat in one location. You only really have to determine the space between the pieces and make sure your mounting holes are level. | | | | | Joined: Jan 2005 Posts: 279 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 279 | Originally posted by 3100 Special: I can measure for you once I take off my trim but, it'll be a while before I make it to that. a personal deal should be personal - please use email or a Private Message | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Nice to see you finally found the "Bolt" Jaime. | | |
