Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (WICruiser, Peggy M, Thom75, Otto Skorzeny, Joe H, ndkid275), 372 guests, and 4 robots.
Topics128,290
Posts1,058,567
Members48,492
Does anyone have a template on the placement of the trim I have a set that I want to install on my suburban just don't know the location.Any help is appreciated. :confused:
I think the '47-'54 Factory Assembly Manual reprint has install instructions for the trim, which was a RPO for the panel truck only.
knuckle head
knuckle head
Yes, it's shown in the assembly manual.
I can measure for you once I take off my trim but, it'll be a while before I make it to that.
1954 Chevy 3100 Panel Truck
2004 GMC Yukon
2002 Chevy 1500 4X4
"Those who expect to reap the blessings of freedom, must, like men, undergo the fatigues of supporting it."
Thomas Paine, The American Crisis, No. 4, September 11, 1777
You know the trim placement turned out to be pretty much a "go ..no go " proposition. If your fenders are true, the trim only lies flat in one location. You only really have to determine the space between the pieces and make sure your mounting holes are level.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
V
V Offline
Quote
a personal deal should be personal - please use email or a Private Message
Anonymous
Unregistered
Anonymous
Unregistered
Nice to see you finally found the "Bolt" Jaime.
