Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Wickedbass, tclederman, Youngin' Tut 59, UtahYork, Woogeroo), 37 guests, and 5 robots.
Topics128,010
Posts1,055,303
Members48,419
#243155 12/21/2004 8:01 PM
I am running a pre 1960 283 in my 49 sub. Using the short water pump. Having a problem finding brackets for a power steering pump and alternator. The 283 has no drilled and tapped holes in the front of the heads for brackets. There are 4 tapped holes lower down on the front of the block. I have seen early 60s engines with the power steering pump integral on the back of the generator as one unit but I would rather run the alternator. Are brackets available? I have checked a couple of local boneyards with no luck. Can any of you Bolters that have been through this offer any advice? Most of the catalogs have lots of brackets but how do I know what to order? Weeds
#243156 12/22/2004 5:35 AM
When I'm setting up power steering, a/c and alternator in chevy small blocks with fulie heads or power pack heads with no bolt holes in the heads, I order my brackets from Alan Grove Components. http://www.alangrovecomponents.com/
Joe
#243157 12/22/2004 6:41 AM
I think alternators started being used in '63 or '64 and the bosses in the front of the heads started maybe '68? I'm not sure the exact years, but it was something like those...
Finding anything from those years in a wrecking yard will be a challenge!
#243158 12/22/2004 7:55 PM
Chevy1 thanks for the reply. Used your link to Alan Grove. It looks like he has all the brackets and pulleys I need although I will probably call him to find out what I need to order.
Weeds
#243159 12/22/2004 8:00 PM
Old Sub. Thanks for the info. Its back to the junkyards.
Weeds
