2 members (Gray_Ghost, Joe W),
211
Mod | | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | I just wired switches on all the doors to turn on the dome light. Had a little help from the guys at ChevyTalk. The fun part was getting the wire back to the rear door. That took 2 or 3 hours alone. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Yeah those guys at ChevyTalk are great. Which approach did you end up using?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | The simple one. I spliced into the ground and ran that wire to all 3 switches. When a door opens the switch grounds and wala! Light! | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Light can be a wonderful thing!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | I just installed a cool retro bypass switch. If the doors need to stay open the switch will bypass the door switches. This was so easy. You guys should try it if you don't have door switches. I just need to figure out how to label it. [img] http://hesproductions.com/59sub/images/dome-light/bypass-switch.jpg[/img] | | | | | Joined: Oct 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 47 | Hey man. Groovy Knob!
I've built a bunch of home audio gear... Amps/pre-amps/speakers.... stuff like that. Whenever I need something marked, and it has to look nice, I take it to a Trophy store. They have the means to engrave on the strangest surfaces. You could also just have them make you a small plaque. You can choose the font to blend with the rest of your dash stuff.
Just a thought. Nice orange color too!
-Joel
'52 3800 Panel School bus conversion... Glass all around. (check the gallery!)
outside of a dog, a book is a man's best freind. inside of a dog it's too dark to read. -Groucho Marx
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | That's a nice looking label, but I liked this better: [img] http://www.oldsub.com/images/2004/12/Dome_Light_Bypass.jpg[/img] Since none of the other controls are labeled I don't think I'd label it at all. How often do you let anyone else drive it? In the last three years the only other people to drive my Suburban have been the oil change guys...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | Steve you are soooo right | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | And its less work, which allows more time to work on the next project!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | Since I had to take the inside trim down to snake the wire to the back door I have been thinking how hard it is to get it back up. Sooooo, The next project may be headliner. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Can you tell me where you found the font for the photo of your bypass switch? I think it's called magneto, but I'm not sure where to find it. | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | I found it on a font search somewhere. It's been 3 or 4 years ago. magneto is correct. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Heck, I have to use the switch on my cab.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | Joker, you could install one switch in less than 30 minutes. It's so simple. All you need is some simple electric connectors, one door switch, a soldering iron and a voltmeter. | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | garretthes can you give alittle more details. I need to add some to my 49 burb. Is there a schematic somewhere?
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | Just curious Garrett, did you add an "on" position to the dome light bypass, or do you have that on your headlamp switch?
Don't lose your head to save a minute, You need your head, your brains are in it. Burma-Shave (1947)
| | | | | Joined: Sep 2004 Posts: 221 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 221 | I have the "on" position in the headlight switch. | | |
