3 members (Otto Skorzeny, 1955 1 Series, Wheelie), 165 guests, and 2 robots.
Topics128,081
Posts1,056,078
Members48,434
#243113 12/07/2004 5:42 AM
I just wired switches on all the doors to turn on the dome light. Had a little help from the guys at ChevyTalk. The fun part was getting the wire back to the rear door. That took 2 or 3 hours alone.
1959 Chevy Apache-Suburban
5.3, 4L60e, Camaro Subframe, enjoy doing the work ourselves!
More on Hotrodders
Driving the past into the future.
#243114 12/07/2004 8:46 PM
Yeah those guys at ChevyTalk are great. Which approach did you end up using?
#243115 12/08/2004 3:26 AM
The simple one. I spliced into the ground and ran that wire to all 3 switches. When a door opens the switch grounds and wala! Light!
More on Hotrodders
#243116 12/08/2004 4:52 AM
Light can be a wonderful thing!
#243117 12/08/2004 5:50 AM
I just installed a cool retro bypass switch. If the doors need to stay open the switch will bypass the door switches. This was so easy. You guys should try it if you don't have door switches. I just need to figure out how to label it.
[img]http://hesproductions.com/59sub/images/dome-light/bypass-switch.jpg[/img]
More on Hotrodders
#243118 12/08/2004 6:04 AM
Hey man. Groovy Knob!
I've built a bunch of home audio gear... Amps/pre-amps/speakers.... stuff like that. Whenever I need something marked, and it has to look nice, I take it to a Trophy store. They have the means to engrave on the strangest surfaces. You could also just have them make you a small plaque. You can choose the font to blend with the rest of your dash stuff.
Just a thought. Nice orange color too!
-Joel
'52 3800 Panel
School bus conversion... Glass all around. (check the gallery!)
outside of a dog, a book is a man's best freind.
inside of a dog it's too dark to read.
-Groucho Marx
#243119 12/08/2004 6:45 AM
That's a good idea. I was thinking of a chrome plate that sort of wrapped around the bevel of the switch. Like this sort of....
[img]http://hesproductions.com/59sub/images/dome-light/label.jpg[/img]
More on Hotrodders
#243120 12/08/2004 5:46 PM
That's a nice looking label, but I liked this better:
[img]http://www.oldsub.com/images/2004/12/Dome_Light_Bypass.jpg[/img]
Since none of the other controls are labeled I don't think I'd label it at all. How often do you let anyone else drive it? In the last three years the only other people to drive my Suburban have been the oil change guys...
#243121 12/09/2004 3:14 AM
Steve you are soooo right
More on Hotrodders
#243122 12/09/2004 5:21 AM
And its less work, which allows more time to work on the next project!
#243123 12/09/2004 5:44 AM
Since I had to take the inside trim down to snake the wire to the back door I have been thinking how hard it is to get it back up. Sooooo,
The next project may be headliner.
More on Hotrodders
#243124 12/18/2004 12:19 PM
Anonymous
Unregistered
Anonymous
Unregistered
Can you tell me where you found the font for the photo of your bypass switch? I think it's called magneto, but I'm not sure where to find it.
#243125 12/18/2004 7:40 PM
I found it on a font search somewhere. It's been 3 or 4 years ago. magneto is correct.
More on Hotrodders
#243126 12/19/2004 5:57 AM
Heck, I have to use the switch on my cab..
Redryder pix
My Hotrod
#243127 12/19/2004 7:23 AM
Joker, you could install one switch in less than 30 minutes. It's so simple. All you need is some simple electric connectors, one door switch, a soldering iron and a voltmeter.
More on Hotrodders
#243128 01/10/2005 5:15 PM
garretthes can you give alittle more details. I need to add some to my 49 burb. Is there a schematic somewhere?
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
#243129 01/10/2005 6:58 PM
Moderator
Moderator
Just curious Garrett, did you add an "on" position to the dome light bypass, or do you have that on your headlamp switch?
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
#243130 01/10/2005 7:29 PM
I have the "on" position in the headlight switch.
More on Hotrodders
