8 members (Hotrod Lincoln, tclederman, 2-Ton, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom),
167
0
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I drove the '56 this evening with the new Goodwrench 350. It took about 3 weeks to change it due to this, that and the other but.......It lives!
Why did I pull a good running 350 and install a new one? Here's the story.
I installed AC before the trip to Kansas City. When installing the compressor brackets I discovered the PO had stripped the threads in the head for one of the intake manifold bolts. Then he stuck a larger bolt with fine threads in the hole. It worked fine until I put a bracket there. It developed an ever so slight coolant leak there. It wasn't more than a seep and I drove it to KC that way.
When I got back, I tried to fix it with a longer bolt. That stripped it out good and I had a major leak.
I debated what to do. Fix this head with an insert? It already has 2 inserts in exhaust manifold bolt holes. The guy must not have owned a torque wrench. Find a set of replacement heads? Either way I'd want to do a valve job while I had them off. But the last time I did that to an old engine it started smoking soon after. So I'd want to do a ring job too.
Then it hit me. I have a boat I let freeze up and bust the block a few years ago. Why not put this engine in it with the boat engine heads and get a new engine for the '56?
And so it went. For the most part a direct bolt in swap. But they forgot to drill and tap a hole for one of the exhaust shields. I drilled a hole for it and broke a tap off in it. I couldn't find a tap extractor locally so I ordered one off the Internet and had to wait for it. Tuesday night I had it all together and filled it with coolant to fire it up. Uh-oh. I put the heater hose fitting in the water pump too tight and busted the casting. So Wednesday I got another new pump and painted it. Installed today and fired it up. It ran a few minutes then died. WTH? The terminal broke on the ignition wire to the distributor. I soldered up a longer wire and she fired right up again. Then the test drive.
I still have some finishing up to do but that's the easy part. I'm happy to have this thing drivable again. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | whew, make me tired just reading that cletis. But thats the way it goes at times. Glad to see you up and running. Now you can take the little lady for a spin! Now that you are all caught up you can come out and help me get the panel going  | | | | | Joined: Mar 2006 Posts: 143 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 143 | Congratulations--I have to admit that everything that I try to fix turns into an "adventure" like you described-- but that is part of the fun. Really like your truck. Glenn | | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Great Cletis! Now have some fun.  | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | glad you got the baby on the road, is it any quicker then the old one or about the same?
I am going to put my rod in the shop next month and get the interior finished,,suspose to be in in nov 26th, the guy said he would probably keep it a max of 2 weeks....ever thing but the seats and carpet, they are in good shape, the rest is all insulation..
see ya Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Joker, it ran too fast for the old truck suspension before. I'm sure it can still scare me.
Glad to see you are getting yours prettied up. | | | | | Joined: Aug 2002 Posts: 117 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 117 | Just goes to show,if you want something Bad enough,you have to Go for it,,don't let anything get you down,in the end,it all pays off...Way to go Cletis,you're an inspiration to Us all!  | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Ah shucks guys. You're embarrassing me. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | cletis, its only about that same distance to S.C. as it is to K.C. and if you will come help me on the old panel I'll brag on you even more  and Victoria can take June shopping while we play!! | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | cletis, how about that boat project now? That was sure a good excuse to get a new engine for the '56, and June can't be requesting some quid pro quo since you've got to get the boat running. Clever!
Man, don't you hate breaking off a tap? It's never a good thing and you were lucky to get it out with the extractor. I've had to resort more than once to taking a pin punch and slowly breaking it into little pieces until it was loose enough to get out.
Congratulations on the engine change,
Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | |
