Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 28 guests, and 3 robots.
Topics128,009
Posts1,055,293
Members48,419
#241 07/07/2002 12:41 AM
Ok, I am doing the following things and would like to know what materials you guys recommend to use in conjunction with the stock gaskets.
1. Oil pan gasket
2. head gasket (I read to use some spray on copper stuff)
3. Intake manifold to head.
4. Intake manifold to exhaust (I assume nothing)
5. Intake to carb base.
6. Exhaust manifold to head. (I assume nothing)
7. Thermostat housing.
8. Valve cover/sidecover.
Thanks, it will save me buying all the wrong things just because the labels look good.
54 3100 with 235
62 flatbed dump C60 with 261
#242 07/07/2002 2:06 AM
I glue the cork valve cover gasket to the cover with 3M weather strip adhesive. The gasket stays put and the cover can be removed and replaced many times with no leaks.On all other gaskets,including the intake, I use Hylomar gasket dressing.It makes for a no leak joint and the gasket can be removed easily if necessary.Some 261/235 head gaskets have a slippey coating that won't take a sealer very well,use em dry I guess.Otherwise , Hylomar or a typical dedicated head gasket sealer like the copper stuff or even aluminum paint works fine.I never use silicone type sealers on engines,except occasionally on a thermostat housing.Seen guys glob on the silicone and sometimes it finds its way into areas it doesn't belong.Permatex "The Right Stuff" is a urethane based product, I believe, and just like the stuff factories use on new engine gasketless joints. Unlike silicon,its ready to go immediatly.Make sure all your sheetmetal parts have straight flanges so they press on the gasket equally .
#243 07/07/2002 4:09 AM
Tony,
Do you glue the gasket on the lifter cover as well? Seems like another place that might work well.
