| | | Forums66 Topics128,005 Posts1,055,253 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Ok, I am doing the following things and would like to know what materials you guys recommend to use in conjunction with the stock gaskets.
1. Oil pan gasket 2. head gasket (I read to use some spray on copper stuff) 3. Intake manifold to head. 4. Intake manifold to exhaust (I assume nothing) 5. Intake to carb base. 6. Exhaust manifold to head. (I assume nothing) 7. Thermostat housing. 8. Valve cover/sidecover. Thanks, it will save me buying all the wrong things just because the labels look good.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | I glue the cork valve cover gasket to the cover with 3M weather strip adhesive. The gasket stays put and the cover can be removed and replaced many times with no leaks.On all other gaskets,including the intake, I use Hylomar gasket dressing.It makes for a no leak joint and the gasket can be removed easily if necessary.Some 261/235 head gaskets have a slippey coating that won't take a sealer very well,use em dry I guess.Otherwise , Hylomar or a typical dedicated head gasket sealer like the copper stuff or even aluminum paint works fine.I never use silicone type sealers on engines,except occasionally on a thermostat housing.Seen guys glob on the silicone and sometimes it finds its way into areas it doesn't belong.Permatex "The Right Stuff" is a urethane based product, I believe, and just like the stuff factories use on new engine gasketless joints. Unlike silicon,its ready to go immediatly.Make sure all your sheetmetal parts have straight flanges so they press on the gasket equally . | | | | | Joined: Dec 2000 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2000 Posts: 54 | Tony, Do you glue the gasket on the lifter cover as well? Seems like another place that might work well. | | |
