3 members (Phak1, Otto Skorzeny, TexasA&M48Truck), 110 guests, and 1 robot.
Topics128,092
Posts1,056,040
Members48,433
#241042 09/20/2007 4:11 PM
Got a leaking pinion seal in an original 57 rear end. I changed the seal, and when it was apart I noticed much pitting in the yoke surfaces. I changed the seal but is still slinging oil.
Many years ago, I made oil field salt water pumps last a bit longer by JB Welding similiar surfaces and sanding it smooth to fill the pits. Reckon this might hold up to oil and to this application for a while? Thoughts?
#241043 09/20/2007 5:51 PM
Welcome to the bolt! The JBWeld sounds like a plan to me. I've heard of guys using it to repair engine block cracks, so it should do the trick for you.
#241044 09/20/2007 7:01 PM
I think it souns like a real good idea to. Id just make sure she was good and clean before applying any.
Ive read here that people have used a speedi-sleeve on parts like this to. Havent had any experience with them myself, maybe someone will chime in???
Jeff
My 1953 Chevrolet
1947.1 Gallery
#241045 09/20/2007 7:02 PM
Oh yeah, welcome! And wheres the pics???
My 1953 Chevrolet
1947.1 Gallery
#241046 09/20/2007 9:32 PM
Riding in the Passing Lane
Is it possible the grease is comeing through the splines. It,s a good idea to put a little RTV on the yoke splines before putting it on. Are the bearings O.K.? Loose brgs. can cause a leak also. The seals usually don,t leak that soon from a rough yoke surface, although it certainly shortens the life. You might check the parts store & see if a speedy sleeve is available for that. That is the best way to go.
1972 Chevy c10 Cheyenne Super
#241047 09/20/2007 9:36 PM
Apprentice
Apprentice
57CHEVY501,
I used a spedi-sleeve to fix mine that had huge grooves in it. It worked great!
A local parts house should be able to help you choose the right one. (if not I think that I saved the old box from the one I used - I can try to find it).
A tip on installing it: Boil your sleeve in water and stick your yoke in a bucket of ice water - this way when you install the sleeve it slides on pretty easily. Once they equalize in temp it is on to stay!
Good luck.
Carl
CCB
#241048 09/21/2007 5:04 AM
Thanks for the advice. Never heard of a spedi-sleeve. I will try that and let you know if it works.
Rustednuts, pics? Are you kidding? With my computer skills? hehe I'll work on that. This is the start of what looks like will be a long project. Work until the money is gone. Save more. Work. Save. You get the picture.
#241049 09/21/2007 5:07 AM
Thats the problem, we didnt get any pictures! grin
My 1953 Chevrolet
1947.1 Gallery
#241050 09/21/2007 5:54 AM
J M Offline
I have used speedi sleeves for years. It will definitely give the seal a good surface to ride on, and is a lot cheeper then a new yoke. I put one in my wrecker last year, and it hasn't leaked since.
Good luck, and welcome to the bolt.
Jim
#241051 09/22/2007 12:04 AM
I've also heard them referred to as "redisleeves"-of course we don't speak english around here. That's topic for a different day.
