| | | Forums66 Topics128,095 Posts1,056,072 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 69 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 69 | Got a leaking pinion seal in an original 57 rear end. I changed the seal, and when it was apart I noticed much pitting in the yoke surfaces. I changed the seal but is still slinging oil. Many years ago, I made oil field salt water pumps last a bit longer by JB Welding similiar surfaces and sanding it smooth to fill the pits. Reckon this might hold up to oil and to this application for a while? Thoughts? | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Welcome to the bolt! The JBWeld sounds like a plan to me. I've heard of guys using it to repair engine block cracks, so it should do the trick for you. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I think it souns like a real good idea to. Id just make sure she was good and clean before applying any.
Ive read here that people have used a speedi-sleeve on parts like this to. Havent had any experience with them myself, maybe someone will chime in???
Jeff | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Oh yeah, welcome! And wheres the pics??? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Is it possible the grease is comeing through the splines. It,s a good idea to put a little RTV on the yoke splines before putting it on. Are the bearings O.K.? Loose brgs. can cause a leak also. The seals usually don,t leak that soon from a rough yoke surface, although it certainly shortens the life. You might check the parts store & see if a speedy sleeve is available for that. That is the best way to go. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2006 Posts: 23 Apprentice | | Apprentice Joined: Sep 2006 Posts: 23 | 57CHEVY501,
I used a spedi-sleeve to fix mine that had huge grooves in it. It worked great!
A local parts house should be able to help you choose the right one. (if not I think that I saved the old box from the one I used - I can try to find it).
A tip on installing it: Boil your sleeve in water and stick your yoke in a bucket of ice water - this way when you install the sleeve it slides on pretty easily. Once they equalize in temp it is on to stay!
Good luck.
Carl
CCB
| | | | | Joined: Aug 2007 Posts: 69 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 69 | Thanks for the advice. Never heard of a spedi-sleeve. I will try that and let you know if it works.
Rustednuts, pics? Are you kidding? With my computer skills? hehe I'll work on that. This is the start of what looks like will be a long project. Work until the money is gone. Save more. Work. Save. You get the picture. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Thats the problem, we didnt get any pictures!  | | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | I have used speedi sleeves for years. It will definitely give the seal a good surface to ride on, and is a lot cheeper then a new yoke. I put one in my wrecker last year, and it hasn't leaked since. Good luck, and welcome to the bolt. Jim | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | I've also heard them referred to as "redisleeves"-of course we don't speak english around here. That's topic for a different day. | | |
