7 members (Chip O, 1955 1 Series, Gray_Ghost, JoergK., Peggy M, oldieoldie, 1 invisible),
177
Mod | | | Forums66 Topics128,191 Posts1,057,348 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 | I am new to this old truck business, and I have alot of questions. How do you get the brake pedals off from the frame. I took off a 7/8 nut from the outside of the frame, but I am not sure how to get the pedal assembly off. It appears to have a long bolt running through it, but the other end has a cap? any help would help? thanks
Tony Jacques
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | | | | | | Joined: Sep 2007 Posts: 37 Apprentice | | Apprentice Joined: Sep 2007 Posts: 37 |
Tony Jacques
| | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | Tony, If the pedal arrangement on your '51 is the same as my '50 the pivot pin (the bolt with a cap on the end you wrote about) goes through the master cylinder bracket -this is on the other end of the pivot pin to the nut you've undone.
To remove the pedal assembly, as well as the big nut you've already undone, you will need to undo another 4 or so bolts that hold the master cylinder bracket to the top and bottom of the driver's side chassis rail. Once you've undone these other bolts this large bracket that holds the pedals will come away along with the brake master cylinder as a single sub-assembly, then you can easily slide the pedals off of the pin once you have removed the retaining clip that sits in a groove on the pin at the opposite end to where the nut fits.
Stuart. | | |
