2 members (Rich'sToys, klhansen), 125 guests, and 1 robot.
Topics128,196
Posts1,057,388
Members48,471
#240875 09/18/2007 4:08 AM
Apprentice
Apprentice
I am new to this old truck business, and I have alot of questions. How do you get the brake pedals off from the frame. I took off a 7/8 nut from the outside of the frame, but I am not sure how to get the pedal assembly off. It appears to have a long bolt running through it, but the other end has a cap? any help would help? thanks
Tony Jacques
#240876 09/18/2007 5:19 AM
Tony - what year/model?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#240877 09/18/2007 2:28 PM
Apprentice
Apprentice
1951 chevy 3100
Tony Jacques
#240878 09/18/2007 3:45 PM
Tony,
If the pedal arrangement on your '51 is the same as my '50 the pivot pin (the bolt with a cap on the end you wrote about) goes through the master cylinder bracket -this is on the other end of the pivot pin to the nut you've undone.
To remove the pedal assembly, as well as the big nut you've already undone, you will need to undo another 4 or so bolts that hold the master cylinder bracket to the top and bottom of the driver's side chassis rail. Once you've undone these other bolts this large bracket that holds the pedals will come away along with the brake master cylinder as a single sub-assembly, then you can easily slide the pedals off of the pin once you have removed the retaining clip that sits in a groove on the pin at the opposite end to where the nut fits.
Stuart.
