1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
sestoring a 1940 chevy 2 ton back to show roon condition need help
located what appears to be the lever for a semaphore style turning signal above the left of the driver side door anyone have any info about this semaphore style turning signal (ie)pictures
drawings or spec. on this matter
(stovebolts will rule one day)
thanks
alberta chevy
Gerard
1940 Chevy 2-Ton (Canadian)webshots albertachevy
That's definitely going to be a Canadian thing, a nod to England. So it would have been a local dealer-installed option. The ones I've seen on commercial trucks from the early days involved a cable-and-pulley arrangement to a lever which, depending on the way it was pulled, flipped one semaphore or the other out, and once it was extended, a contact was closed illuminating the light.
1951 3800
-hotshoe
The semaphore turn indicators I have seen on U.S. trucks were not the same as Brit "Trafficators." They were only on the drivers side and went up to signify a right turn and out to signify a left turn, basically the same as an arm signal. I don't recall if they had the 45 degrees up to signal the intent to stop. Sometimes they show up on ebay.
The ones on my old VW were electric. A long throw solenoid pulled the arm up out of the door frame.
"Happiness equals reality minus expectations" - Tom Magliozzi
you might check John's site here and see if he has a link that might help..
click here
Redryder pix
My Hotrod
