| | | Forums66 Topics128,131 Posts1,056,369 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 24 New Guy | | New Guy Joined: Aug 2007 Posts: 24 | sestoring a 1940 chevy 2 ton back to show roon condition need help located what appears to be the lever for a semaphore style turning signal above the left of the driver side door anyone have any info about this semaphore style turning signal (ie)pictures drawings or spec. on this matter (stovebolts will rule one day) thanks alberta chevy | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | That's definitely going to be a Canadian thing, a nod to England. So it would have been a local dealer-installed option. The ones I've seen on commercial trucks from the early days involved a cable-and-pulley arrangement to a lever which, depending on the way it was pulled, flipped one semaphore or the other out, and once it was extended, a contact was closed illuminating the light. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | The semaphore turn indicators I have seen on U.S. trucks were not the same as Brit "Trafficators." They were only on the drivers side and went up to signify a right turn and out to signify a left turn, basically the same as an arm signal. I don't recall if they had the 45 degrees up to signal the intent to stop. Sometimes they show up on ebay. | | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | The ones on my old VW were electric. A long throw solenoid pulled the arm up out of the door frame.
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you might check John's site here and see if he has a link that might help.. click here Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
