2 members (walter74, klhansen),
117
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 26 Apprentice | | Apprentice Joined: Mar 2007 Posts: 26 | Howdy,this might be a simple question but I have a 57 235 with a bad fuel pump.Looked into replacement or rebuild but Im on a no cash flow system,I have heard that you can replace it with a newer 6 cyl.pump?The cost difference is alot and Im not too worried about orginality.I just want to get it running!Thanks Al
"What Dirty Scoundrel Stole The Cork From My Lunch" W.C. Fields
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Al,
AutoZone sells a fuel pump for $25. NAPA is a few dollars more. Advance Auto is under $23, if you use the 10% discount.
By the way, I'm in Schodack, right outside of Castleton.
Tim | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | You might think about a dual action pump if you have vacuum wipers. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Im on a no cash flow system A dual-action fuel pump is very nice but it would at least triple the cost (1957 pump), just for the pump. Then, there would also be the cost and enjoyment of running the two additional vacuum lines. Put an add in the Swap Meet if you would be interested in a used dual-action fuel pump. I know that someone will have one for sale. Most likely you'll get no guarantee and the price would be at least as much as a new regular fuel pump (with warranty). :hammering: | | | | | Joined: Mar 2007 Posts: 26 Apprentice | | Apprentice Joined: Mar 2007 Posts: 26 | Thanks guys,I can always count on you for good solid answers!Hey tclederman,do you know what the fuel pressure rating is on those new pumps,my old Rochester cant take much pressure Thanks Al
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I don't have an exact pressure figure but mechanical pumps don't put out a lot of pressure. I put a "late model" pump on my 38 & it worked OK on my 216.
I have used one from Autozone with no problems. Most likely they match the pressure of original pumps.
Tim | | | | | Joined: Mar 2007 Posts: 26 Apprentice | | Apprentice Joined: Mar 2007 Posts: 26 | Thanks Guys Ill have to run down to Auto Palace and get a pump.Ill keep you folks posted Al
