0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#240479 09/11/2007 6:58 AM
Apprentice
Apprentice
Howdy,this might be a simple question but I have a 57 235 with a bad fuel pump.Looked into replacement or rebuild but Im on a no cash flow system,I have heard that you can replace it with a newer 6 cyl.pump?The cost difference is alot and Im not too worried about orginality.I just want to get it running!Thanks Al
"What Dirty Scoundrel Stole The Cork From My Lunch" W.C. Fields
#240480 09/11/2007 8:15 AM
Al,
AutoZone sells a fuel pump for $25. NAPA is a few dollars more. Advance Auto is under $23, if you use the 10% discount.
By the way, I'm in Schodack, right outside of Castleton.
Tim
#240481 09/11/2007 12:48 PM
You might think about a dual action pump if you have vacuum wipers. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#240482 09/11/2007 1:43 PM
Quote
A dual-action fuel pump is very nice but it would at least triple the cost (1957 pump), just for the pump. Then, there would also be the cost and enjoyment of running the two additional vacuum lines. eek
Put an add in the Swap Meet if you would be interested in a used dual-action fuel pump. I know that someone will have one for sale. Most likely you'll get no guarantee and the price would be at least as much as a new regular fuel pump (with warranty). :hammering:
#240483 09/12/2007 7:26 PM
Apprentice
Apprentice
Thanks guys,I can always count on you for good solid answers!Hey tclederman,do you know what the fuel pressure rating is on those new pumps,my old Rochester cant take much pressure Thanks Al
#240484 09/13/2007 12:03 AM
Ex Hall Monitor
Ex Hall Monitor
I don't have an exact pressure figure but mechanical pumps don't put out a lot of pressure. I put a "late model" pump on my 38 & it worked OK on my 216.
#240485 09/13/2007 3:03 AM
Al,
I have used one from Autozone with no problems. Most likely they match the pressure of original pumps.
Tim
#240486 09/16/2007 10:41 PM
Apprentice
Apprentice
Thanks Guys Ill have to run down to Auto Palace and get a pump.Ill keep you folks posted Al
