7 members (Hotrod Lincoln, bobfake, GRNHydra, tclederman, Woodcmiami, Otto Skorzeny, 2-Ton), 43 guests, and 2 robots.
Topics128,091
Posts1,056,034
Members48,433
#240168 09/02/2007 2:44 PM
I don't know a whole lot about wheels and was wondering about something. My one-ton has 19-1/2 inch wheels and I am thinking I would really rather have 16's on it. Will stock steel wheels work? Will the 8 lug bolt pattern be the same? Do I need to get special wheels for the duals? Can I recalibrate my speedometer for the new wheels?
LOTSA QUESTIONS! Anything I am not considering that you might see?
Help!
David :confused: ohwell :confused_smile:
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless!
My 1962 Chevy C-30
Help? Anybody?
My 1962 Chevy C-30
You should be able to use just about any 16 or 16.5 dually wheel up to the '91 model year. Bolt pattern is the same, even on ford and dodge. As far as the speedo goes, if you can match the outside diameter of the tire, keeping the same rolling circumference, it shouldn't mess that up too much.
Bill Burmeister
#240171 09/02/2007 10:38 PM
H Online: Content
Oly, the 19.5" is a tubeless height equivalent of an 18" tube-type tire. I doubt if you'll be able to find a 16" tire tall enough to match, so your road speed will drop, and RPM will probably go up noticeably. Is the truck a dual-wheel rig now? My 59 model 3800 flatbed had big enough rear brake drums that 16" wheels would not fit over the drums, so I would have had to go with outside wheels only if I'd swapped to 16's, losing the dual-wheel capability. Something to consider- - - - - -
Thanks Bill and Jerry.
I never thought about a 16 not being able to go over the brake drum. Hmmm.... perhaps I will just have to stay with the 19.5's I mainly just wanted to lower the profile of the truck and improve the handling a little, but if it is going to increase my RPM's too, I think maybe it's not really worth it.
My 1962 Chevy C-30
Socket Breaker
Socket Breaker
You better check around on the prices for tires for 16 inch wheels in your area and consult your budget, if you have one.
My dad went with 16 inch wheels on his '53 chevy truck, and the cost for the tires was much more than 15 inch tires.
Just something to think about.
-W
