3 members (Otto Skorzeny, Peggy M, Joe H), 83 guests, and 2 robots.
Topics128,022
Posts1,055,361
Members48,420
#239405 08/19/2007 6:20 PM
My '49 half-ton has a shock link that has a U-shaped bracket at the top that connects to the bushing of the lever action shock and a straight threaded rod at the bottom that connects to the axel bracket. All the shock links I have seen for sale have the U-shaped bracket on both ends. Anybody out there seen the other type for sale?
#239406 08/20/2007 5:03 AM
Seems you and I have the same shock links which are not reproduced anymore. Used links are like hen's teeth also. I ended up cutting the 8.5" threaded rod off of passenger links and had a local welder weld the old yokes onto the threaded rod. They look and work like the original.
Shock Link
1948 AD Pickup
#239407 08/20/2007 3:00 PM
Thanks for the reply Littlebuddie. There's nothing salvagable on my old links, so I guess I'll be looking for some of those hens.
#239408 08/20/2007 8:32 PM
Do you have double action lever shocks? If so, that probably explains why your links are different. I recall seeing a picture of double action shocks and the links were different.
The double action shocks were options, probably making the links even harder to find, since they are probably quite rare.
#239409 08/21/2007 12:01 AM
Good call Brian, mine are double action lever shocks so jdwilker's shocks would be the same if they have links similar to mine.
1948 AD Pickup
#239410 08/21/2007 2:04 AM
I too have the double-action lever shocks on my 49 3/4T. Had to weld threaded rod to the bracket and used sway bar bushings on the ends. Took a set for an 89 Z24 and drilled them out a little. Fit well and do the job.
I don't look forward to rebuiling the shocks, though.
#239411 08/21/2007 2:23 AM
Quote
(((OOOOOH)), let's not talk about that
1948 AD Pickup
#239412 08/21/2007 2:56 AM
You might paw through the junkyard and see if you can find some sway bar end links off a modern car that fit, they serve a similar function.
Paint & Body Shop moderator
#239413 08/21/2007 3:08 PM
My shocks are single action and the rubber bushing is 1" instead of 3/4" I've seen elsewhere. I'm wondering if maybe they came from a bigger bolt like a 3/4 ton?
#239414 08/22/2007 5:08 PM
I might have a few of the links around here some where if you are interested let me know and I will see if I can dig some up.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
#239415 08/23/2007 2:53 PM
Thanks 41Chevy. I sent you a email regarding this.
#239416 08/23/2007 6:15 PM
James, need to know the length of the link to make sure that I have the right ones, they were 10 inches and 12 inches (top of yoke to end of rod)let me know what size you have.
