7 members (texas46, Stovebolt48, Uncles51, Donf, spanky, Hotrod Lincoln, Southerntruck), 62 guests, and 1 robot.
Topics128,022
Posts1,055,384
Members48,422
#239380 08/19/2007 3:06 AM
I am in the process of dropping the front axel on my 46 and am having problems diconnecting the steering box. Can anybody give me some hints?
Thanks in advance
Ed
#239381 08/19/2007 4:26 AM
At what place would you like to disconnect it?
1952 Chevrolet 3800 pickup
---All pictures---
#239382 08/19/2007 12:29 PM
well,
I am not totaly sure. I think I would like to take the whole box off the frame so I can clean it and the frame. The shaft goes through the frame and the arm is attached, that seems to be the most logical place to disconnect.
Ed
#239383 08/19/2007 1:30 PM
I have not worked on your model truck, but I would guess you need to remove a nut from the end of the pitman shaft. Then with a puller remove the pitman arm.
Or is the arm clamped on the shaft with a cross bolt, even easier to remove?
Grigg
---All pictures---
#239384 08/19/2007 3:55 PM
It has a bolt and then it looks like teeth on the inside, I started to use a puller than thought I should ask to make sure I am doing the right thing.
Ed
#239385 08/19/2007 4:58 PM
Sounds like you know what you are doing then.
Grigg
---All pictures---
#239386 08/19/2007 8:21 PM
Ed, I took mine off from the frame by removeing the nut and then using a wheel puller. Came off nicely. How you doing with that engine? Mike
#239387 08/20/2007 2:07 AM
Mike,
I will send you some pictures soon, my son has it painted and it looks brand new.
I trying to paint the front part of the framne before I put the engine in.
Ed
#239388 08/20/2007 5:10 PM
H Online: Content
If the Pitman arm is slotted, with a pinch bolt tightening it over the sector shaft, the bolt needs to be removed completely, not just loosened. There's a groove in the sector shaft that will keep the Pitman arm from coming off if the bolt isn't taken all the way out. Once the bolt is removed, use a 2-jaw puller to persuade the Pitman arm to move if necessary. Sometimes a few medium-firm taps with a BFH will get the job done! On the steering gears with one large nut on the end of the sector shaft, a very heavy duty Pitman arm puller is definitely required.
#239389 08/21/2007 3:03 AM
I nearly severed my left ring finger using one of those big-arse pitman pullers. Do be careful.
Paint & Body Shop moderator
#239390 08/21/2007 3:53 AM
I beat the crap out of mine and ended up dammaging the sector to the point of no repair. Don't do that.....
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
#239391 08/22/2007 12:39 PM
Thanks guys, I hope to do this this weekend, I will let you know how it goes and if I still have all my fingers.
Ed
#239392 08/25/2007 7:41 PM
Just an update, I went to NAPA today and they where having a sidwalk sale, they had a nice steering pully set for $55.00 so I picked one up.
I got home and put the pitman puller on turned it about ten time with the wrench an pop it was off. I have now dropped the front axel and am all covered in grease from 60 years of oil dripping from my engine.
What a great day.
Thanks for the advice.
Ed
