| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | I am in the process of dropping the front axel on my 46 and am having problems diconnecting the steering box. Can anybody give me some hints?
Thanks in advance
Ed | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | At what place would you like to disconnect it? | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | well,
I am not totaly sure. I think I would like to take the whole box off the frame so I can clean it and the frame. The shaft goes through the frame and the arm is attached, that seems to be the most logical place to disconnect.
Ed | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have not worked on your model truck, but I would guess you need to remove a nut from the end of the pitman shaft. Then with a puller remove the pitman arm. Or is the arm clamped on the shaft with a cross bolt, even easier to remove?
Grigg | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | It has a bolt and then it looks like teeth on the inside, I started to use a puller than thought I should ask to make sure I am doing the right thing.
Ed | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Sounds like you know what you are doing then. Grigg | | | | | Joined: Oct 2006 Posts: 76 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 76 | Ed, I took mine off from the frame by removeing the nut and then using a wheel puller. Came off nicely. How you doing with that engine? Mike | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | Mike,
I will send you some pictures soon, my son has it painted and it looks brand new.
I trying to paint the front part of the framne before I put the engine in.
Ed | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | If the Pitman arm is slotted, with a pinch bolt tightening it over the sector shaft, the bolt needs to be removed completely, not just loosened. There's a groove in the sector shaft that will keep the Pitman arm from coming off if the bolt isn't taken all the way out. Once the bolt is removed, use a 2-jaw puller to persuade the Pitman arm to move if necessary. Sometimes a few medium-firm taps with a BFH will get the job done! On the steering gears with one large nut on the end of the sector shaft, a very heavy duty Pitman arm puller is definitely required. Jerry
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I nearly severed my left ring finger using one of those big-arse pitman pullers. Do be careful.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | I beat the crap out of mine and ended up dammaging the sector to the point of no repair. Don't do that.....
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | Thanks guys, I hope to do this this weekend, I will let you know how it goes and if I still have all my fingers.
Ed | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | Just an update, I went to NAPA today and they where having a sidwalk sale, they had a nice steering pully set for $55.00 so I picked one up. I got home and put the pitman puller on turned it about ten time with the wrench an pop it was off. I have now dropped the front axel and am all covered in grease from 60 years of oil dripping from my engine.
What a great day.
Thanks for the advice.
Ed | | |
