6 members (farmallb, ChevyBlue, 2-Ton, carbking, Hotrod Lincoln, tclederman), 144 guests, and 1 robot.
Topics128,089
Posts1,055,991
Members48,430
#239275 08/18/2007 5:07 PM
When I first had my truck there were rear coil overload springs on it. There was a bracket welded to the top of the axle both sides with a bolt projecting vertically. The springs are tapered, wider at the top and there was a plate on the bottom with a hole for the bolt to go thru. A nut kept them in place.
I have seen leaf overload springs but never coil. It could be some after-market item but the way the bracket is mounted to the axle it appears to be original. It is a Canadian built truck.
Anyone seen these?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#239276 08/19/2007 5:40 AM
The only ones I've ever seen were after-market...
Even though the weld looks original, it may still be an after-market item that a competent welder did the install...
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
#239277 09/01/2007 11:36 PM
Apprentice
Apprentice
I think I have the same kind of system that my body guy said was overboard & we intend to remove the extra coils & leaf springs. The former owners son told me that the truck had been refitted to carry a camper(& messed up the bed sides too). We also had this massive towing hookup so they must have had a boat or RV too.
