1 members (baldeagle),
95
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 52 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 52 | I think I have air in my cooling system after I changed the heater hose on my sbc, and I'm not sure how to get it out? Any ideals?Thanks | | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | take a heater hose off at the highest point of the engine and fill until coolant comes out. and then reinstsall the hose and run the truck with the heater on high until the thermostate cycles a few time. that is how i do it. hopfully im right, have had no problems doin it that way
gotta love old trucks
| | | | | Joined: Jan 2005 Posts: 52 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 52 | THANKS alot. I'll give it a try. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Park it on the steepest hill, pointing up hill, and run it until the thermostat stays open. Works every time, Scott | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If you drill a small hole in the edge of the thermostat that helps it burp a lot faster. I do that in every thermostat I replace. 1/8" is plenty.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jan 2005 Posts: 52 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 52 | Thanks to everyone for the help. What a GREAT site! | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | hot rod ...this is the neatest thing i ever seen for radiators ...it is called a spill-less funnel the thing comes with abought every adapter you can imagine ...an you attach it to your fill hole like a radiator cap ...ya then just keep it full of coolant while the vehicle is runnin an it takes out all the air ...an when ya done there is a long plug ya stick down it to close it off an remove it ...dont make a mess an it removes ALL THE AIR ! | | | | | Joined: Jun 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 191 | Prestone makes a bleeder valve that goes into the heater hose that makes it pretty easy too. | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | I'm with 4 on the floor--a small 1/8-inch hole drilled in the flange of the thermostat is the ticket. Bleeds air out of the engine while you're filling the radiator, and there are no adverse affects. A friend told me about it before I put in my last t-stat, and I'll do it on every one I ever own from here on out. -Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | There is a very simple way to bleed the air out of the straight sixes- remove the tempurature guage sensor from the top of the head, start the engine fill it up with water. Eventually all the air will bleed out of the block and cooling system, then you replace the temperature sensor.
Lots of the newer thermostats come with the small hole metioned in the other post. If you are shopping for a new one, you might keep an eye out for one with the hole.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Tim, ya wouldn't have a picture of that "Spill- less funnel" thingie that you discribed, 1000 words, remember. I have 7 thermostats here all new for various vehicles and I don't see any with holes drilled in the flange. I'd be real carful pulling the temperature sender that has the sealed capalary tube. The bulbs are fairly sensitive and the seal is easily broken and then ya got a pain in the arse gettin it fixed or replacing it with a new one. I'm with Scott on this one, just elevate the front of the truck. Denny Graham
Denny G Sandwich, IL
