12 members (Joe H, Gray_Ghost, Woodcmiami, fonz8261, 2-Ton, cmayna, 55shaker, kades51, Forty9, NorthCoast3800, Robert Crandall, 1 invisible), 103 guests, and 3 robots.
Topics128,169
Posts1,057,037
Members48,458
Was gonna order some stuff from LMC for the brakes in my '72 but ran into a question that they don't have anyone around to answer. Maybe someone here can help, since I'd like to get the stuff ordered ASAP.
They have a complete pre-bent stainless brake line kit that says it's only for coil-spring applications. My '72 has leaf springs out back. Anyone know what the difference in the brake lines is and why this wouldn't work for a leaf spring application?
Link: http://lmctruck.com/icatalog/cb/0143.asp
Brent
I would think the only difference would be the shape at the rear section would be a tad different. The coil rear widens as it goes over the diff where as the leaf is pretty much straight back. I'ld bet you could make the pre-bent line work with some minor tweaking of the bends,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
