1 members (RLB), 77 guests, and 2 robots.
Topics128,105
Posts1,056,541
Members48,448
#238276 08/01/2007 6:13 AM
Junior Member
Junior Member
Greetings, I have a 1951 3100 PU, installed dual carbs on a offie intake manifold and the back carb sits just where the fender support rod goes, can I get away with not having the support rods (the rods that run from the firewall to the inside of the fender)? I have seen some trucks that elected not to use the rods because something got in the way and other guys that say they have to be there. I know they were designed to be there BUT, can a person SAFELY not use them?
Inquiring minds need to know. Lloyd from Washington
I have seen the rod modified to go around an obstacle. That would be my approach to the problem.
1951 1 Ton Completed
Y
Y Offline
Lloyd, the rods serve two funtions, if you have the radiator support with the single "center" mount the rods keep it level, but I think the main purpose is for adjustment/alignment of the fenders/aprons. I know it helps keep the hood and fenders from hitting. Just my 2 cents
Phil
I put dual carbs on my '54 GMC, modified the left support rod by bending it out of the way of the rear carb. I think it is wise to keep it, the front fender will start to sag if you take it off.
