| | | Forums66 Topics128,096 Posts1,056,482 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 5 Junior Member | | Junior Member Joined: Nov 2005 Posts: 5 | Greetings, I have a 1951 3100 PU, installed dual carbs on a offie intake manifold and the back carb sits just where the fender support rod goes, can I get away with not having the support rods (the rods that run from the firewall to the inside of the fender)? I have seen some trucks that elected not to use the rods because something got in the way and other guys that say they have to be there. I know they were designed to be there BUT, can a person SAFELY not use them? Inquiring minds need to know. Lloyd from Washington | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have seen the rod modified to go around an obstacle. That would be my approach to the problem. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Lloyd, the rods serve two funtions, if you have the radiator support with the single "center" mount the rods keep it level, but I think the main purpose is for adjustment/alignment of the fenders/aprons. I know it helps keep the hood and fenders from hitting. Just my 2 cents Phil | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I put dual carbs on my '54 GMC, modified the left support rod by bending it out of the way of the rear carb. I think it is wise to keep it, the front fender will start to sag if you take it off. | | |
