8 members (Gdads51, 2-Ton, Naturalthud, DoubleB, Barney1951, Hotrod Lincoln, Hanks custodian, 1 invisible),
120
0
Mod | | | Forums66 Topics128,081 Posts1,056,070 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 36 | ANY ADVICE ON CLASSIC TRUCK INSURANCE ?
It's not the speed you travel it's the quality of the trip that matters !!!
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | By "classic truck", I assume you mean a truck that is not a daily driver. If that is the case, allot of the major insurance companies will carry your classic vehicle on your family policy, with some possible driving limitations. In some cases they may even move you to one of their "specialized coverage" companies to give you a lower rate. In many cases, you must have an equal number of cars to the number of drivers in the household. For example, if you have two cars and your classic vehicle and three drivers, they will not give you full coverage on the classic vehicle because it becomes apparent that someone may be driving the classic vehicle on a regular basis. So, assuming you have enough vehicles to exclude the classic vehicle form the daily driving routine, most of the companies will give you full coverages providing you agree to and can prove a "stated value". A "stated value" usually requires an written qualified apprasial of the vehicle. That's about it, and even if you choose a specialized company for your coverage, you will still have to prove value and you will be limited on your coverage. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | in PA if you get either the classic or antique plates ...you can get cheap insurance but both plates come with restrictions . Drivin at nite , so many miles per ....etc .. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | As Joe pointed out, the major insurance carriers offer some exceptional rates for their multi-line customers and I found that I could secure full coverage on my 54 truck with only some minor limitations. This was at a lower rate than the collector car insurers. There are obvious advantages to being able to sit down, face to face with your agent and purchase the specific coverage you want. Getting a full explaination of just what your policy covers, before you need it, just makes good sense.
I can't speak to the service provided by the specialty company insurers because I've never been forced to use them!!! Sometimes the best deals are right under your nose!!!
Dave | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | Some specialty companies like J.C. Taylor will only insure a stock vehicle, 2500 annual mileage, no work/daily use, and it must be garaged. They go up to 30K without an appraisal. Haggarty and others have similar requirements, some are more liberal on miles and modifications. Fred
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Read Insuring your truck in the Stovebolt Tech Tips. | | | | | Joined: May 2007 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 36 | AAA covered my 55 gmc for $45,000.  | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | In addition to the expected limitations (miles/year, no work commute, etc.) I am not allowed to tow a trailer.
The agent that carries all of my other policies wrote me up for my Bolt.
I told the company my truck's stated value and did not have to provide an appraisal so long as it is below $25,000.
Bill | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | i went to my local farm bureau agent. we have it insured for agreed value ($15K) with no mileage restrictions.
i only had to supply an appraisal and we took a ton of pics. the appraisal was simple, went to a local car dealer and he wrote the value on his letter head.
full coverage = $281.00/year. not sure if it's high or not, but i drive it a lot and don't want the restriction. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Shop around starting with your regular insurance co.If you have no luck with them there are many insurance cos. that cater to classic vehicles.Mine are insured thru my reg.ins.co.Not supposed to be used as a regular driver,but who knows what you do.Basically the same restrictions as historical license plates. | | |
