3 members (3B, 55shaker, Gdads51), 103 guests, and 1 robot.
Topics128,130
Posts1,056,367
Members48,441
#237396 07/18/2007 12:16 AM
Can anyone recommend a machine shop to do some minor lathe work? I need a shifter shortened and threaded. Thanks in advance. wink
Joe smile
Joe:
I would use the yellow pages and find one close by. Most machine shops should be able to handle that job. They may not want to take on such a small job.
I have one I use in Dallas that would not normally do small jobs but one of their machinists is a friend of mine.
Good luck.
~Jim
Joe,
Here's the guy you need to call. He's is in Crowley, TX just south of Fort Worth. Not only is he a pro machinist, but he has owned old trucks from the 40s and 50s. He does a lot of work on old vehicles.
Give him a call at 817-683-5832. Tell him his cousin Louis told you to call.
Joe,
if he doesn't want to do it try Hoop's welding in Denton.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
Does it have to be turned on a lathe or can it just be cut ground down and welded. I might be able to help you I'm in Azle and own an Ornamental Iron manufacturing shop.
#237401 07/27/2007 10:12 PM
Joe, I met the Beaver,, bet he could take care of it..plus he is cheap,, just kidding, dont know about the cheap..
might have a guy here in mesquite, I would have to pick up your truck and drive it here though grin he fixed me up on my 52 to give me a longer stem, made it where it scewed into the orginal s-10 shifter but added a couple of inches or so , I hated having to bend down a little to shift,, worked well, charged me 70 bucks but it looked good
Redryder pix
My Hotrod
#237402 07/27/2007 10:12 PM
Get out your hacksaw and your tool and dies. Guess I don't understand the problem if you can't.
#237403 07/29/2007 12:01 PM
Thanks for the recomendition Joker.
