9 members (rfs56trk, 78buckshot, 2-Ton, Gdads51, Wheelie, Deegs53, Peggy M, Gray_Ghost, 1 invisible),
149
Mod | | | Forums66 Topics128,078 Posts1,056,024 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 6 New Guy | | New Guy Joined: Aug 2002 Posts: 6 | I have a 51 Suburban with straight axle disc brake conversion (78 GMC Rotor stuff). Will 2004 17 inch Chev Tahoe steel stamped rims fit without hitting any tie rod ends or whatever? Would like to know before I go look at rims. Thanks. OldArmy. Recalled and serving just one more time..... | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Most of the late model stuff has a wild offset on the wheels. They would be in way too far. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Thass what I think. '87 and back is what works. Not absolutely sure, though. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Short answer, no. Really, anything after '88 won't work. What you want is 3 1/2 - 4 1/2" backspace, the late stuff uses a 5 1/2' backspace.
Bill Burmeister | | | | | Joined: Aug 2002 Posts: 6 New Guy | | New Guy Joined: Aug 2002 Posts: 6 | Thanks everyone. It was a good deal too. Appears that I will have to keep looking. OldArmy | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | didn't I read on here, somewhere, that Blazer 4x4 and suburban will work up to 92??? Hmmm, now I'm wondering. Just stay with 87 back and I guess I won't need to guess. Right !!! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Actually, it's '91 on Blazer and 'Burb. They carried over the R/V body along with some versions of the 1 ton, namely the Crew Cab and Chassis cab models, usually with dual wheels on those models.
