1 members (Gib70),
177
Mod | | | Forums66 Topics128,089 Posts1,056,117 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | A hair over 8,000 lb., I weighed it. Check this out: [img]http://thumb11.webshots.net/t/58/458/7/44/12/2124744120096215731fweGsP_th.jpg[/img] Timbers from BC Hydro, the electric company now owned by some outfit form Georgia. USA, I mean, not Russia. It hides pretty good on there, look at this: [img]http://thumb11.webshots.net/t/52/452/5/18/15/2438518150096215731MUQyOn_th.jpg[/img] I could almost fake being legal, except for Epic's butt draggin' like that. TWO TONS of payload on there. 5,650# on the drive axle. Not exactly what you'd call compliant, y'know. I drove around a while to see how she'd handle it: No problem. The steering axle didn't even float. I found a 15% grade, and pulled up it at the top of second gear. I could have shifted up if the gears weren't so long. No rise in engine coolant temperature, no stink, nothing. Effortless, apparently. So then I went to a buddy's house and got legal, comparatively speaking. Look at his lawn ornament: [img]http://thumb11.webshots.net/t/62/462/5/6/63/2813506630096215731xRExGQ_th.jpg[/img] Purty nice, huh? I think it's, like, a '69 or somewhere 'round there. nice unit, no problems, but he doesn't want to work it at local cut rates, so it's getting a drom deck, and it's going to be a patio. Cool or what? 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | prettygood load. truck doing what it was designed for work. | | | | | Joined: Sep 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 191 | Hey hotshoe, the old truck looks good working. I see from your pics that ya got the Mihindra, do ya like with the little diesel? | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Rob; I wouldn't have a single clue what a Mahindra could be if I hadn't researched that Jeep before buying it. This one is actually an '87 Mitsubishi. [img]http://thumb11.webshots.net/t/63/463/5/34/34/2467534340096215731LCZagQ_th.jpg[/img] Mitsubishi built these from 1953 to 1998, originally under contract to Willys-Overland. It has a 2.7l turbo diesel which I like a bunch. Lots of poop - around 100 hp, as compared to my Chevy's 90 - and gets 30-40 mpg, depending on how I drive it. It has a 75 mph top speed (pretty twitchy up there) cruises nicely at 60 mph, but goes further on fuel if it is allowed to stay around 50 or less. I've sourced an overdrive, but it will be a bit spendy, so I'll wait to see if this Jeep survives its first few years of service to me. It probably will: it seems plenty strong, and only had around 35,000 miles when I bought it. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | nice load... much more than both of my Rod's will carry.
| | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Looks like it carried the load really well. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | nice payload there. Your buddy's truck looks well stacked as well. | | | | | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | What a testament to your truck. Did it stop good?
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
| | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Good question, 49. It could have stopped better, I think. Not sure how those brakes should work with that much weight, but one of the reasons I put that much on it was to find out how the brakes would handle the load. They were okay: a time or two in traffic when I was cut off approaching a traffic light, it felt as if I was using a lot of what was there, but they did the job. I think, though, that I'll be trying to fine-tune them before loading like that again. It took a good, strong shove on that pedal to bring her down any kind of soon. Okay enough if you're ready - like on snow - but if I was to fully load her regularly, my right leg would get stronger.
Once I lightened her down to maybe 6800 GVW, she was fine. I even did some sportscar stuff on a curve or two, and it was fun! 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | Sounds like your brakes are working about like they are supposed to work. I had a 69 chevy 1 ton that had to carry that "extra" load every once in a while. Just remember most trucks will "GO" down the road with a lot more load they can "STOP" with. Also, make sure those tires will carry the load. Your truck is a beauty!
| | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Thanks, 49. The tires are the best I could find: rated for 3,072 lbs @ 80 psi. The rims are alloy - lighter and stronger than the originals - and the brakes (along with most everything else under there) are recently overhauled. I looked into buying different wheelnuts when I switched the rims, but my tire guy tells me the old ones are up to spec, and the only thing new nuts would do is prettify the wheels. [img]http://thumb11.webshots.net/t/64/464/1/66/92/2280166920096215731GIYLPh_th.jpg[/img] Well, I went out yesterday and bought chrome center caps to thank the old girl for doing such a good job, so I'd imagine the nuts might be next. But if I did that, I suppose I'd have to start thinking about paint, wouldn't I? 1951 3800 Be the change you want to see. -hotshoe
