0 members (),
79
Mod | | | Forums66 Topics128,021 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 102 | Question about the stock heater on a 52 3600. Does this heater have a fan in it? I have a spare and its doesn;t look like much more than a core with some sheet metal around it. Sometime in my trucks life a mopar deluxe heater was installed in place of the orginal heater unit. It works wonderfully so I don;t plan on changing it. I was just curious about the stock unit. I figure this happened for probably only one reason. I belaive the orginal engine was changed out for a later model 235 that was 12 volt. either mopar parts were cheap or the farmer had an old mopar car or something laying around as not only is the heater mopar but so is the alternator. Nevertyhe less the mopar heater hads a fan unit and works very well. Birge  | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | The heater should have had a fan in it. The original heater in my '48, which was a factory option back then, has a fan. I can't imagine they'd take the fan out of the heater in later years. | | | | | Joined: Jun 2007 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 102 | Maybe I am just not looking hard enough. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Is the core round? There should be a fan motor in the center. | | |
