5 members (Randy Baumann, TexasJim50, 52Carl, dt235sd, 1955 1 Series), 77 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#237166 07/13/2007 3:25 PM
Question about the stock heater on a 52 3600. Does this heater have a fan in it? I have a spare and its doesn;t look like much more than a core with some sheet metal around it. Sometime in my trucks life a mopar deluxe heater was installed in place of the orginal heater unit. It works wonderfully so I don;t plan on changing it. I was just curious about the stock unit. I figure this happened for probably only one reason. I belaive the orginal engine was changed out for a later model 235 that was 12 volt. either mopar parts were cheap or the farmer had an old mopar car or something laying around as not only is the heater mopar but so is the alternator. Nevertyhe less the mopar heater hads a fan unit and works very well.
Birge grin
Birge
1952 Cheverolet 3600
http://www.flickr.com/photos/bilge77/
#237167 07/13/2007 4:57 PM
The heater should have had a fan in it. The original heater in my '48, which was a factory option back then, has a fan. I can't imagine they'd take the fan out of the heater in later years.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
#237168 07/13/2007 5:16 PM
Maybe I am just not looking hard enough.
Birge
#237169 07/13/2007 5:47 PM
Is the core round? There should be a fan motor in the center.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
