3 members (Bill Hanlon, DES57, Tom McGrath), 118 guests, and 0 robots.
Topics128,117
Posts1,056,296
Members48,439
#236823 07/06/2007 6:06 PM
Junior Member
Junior Member
So when I'm driving around and come to a stop and turn off the engine it sometimes sputters and makes weird noises even though the ignition is turned off. Is their still gas in the carb? Why is this happening? It does it once in a while but not all the time. Just curious.
#236824 07/06/2007 6:12 PM
First guess is the timing is off causing the engine to "disel". I'd check it first thing. If that doesn't work let us know and we'll give you reason # 2-25....welcome to the bolt. Great place for questions and answers.
#236825 07/06/2007 6:21 PM
For me, this has always been a vacuum leak.
#236826 07/06/2007 6:45 PM
Ex Hall Monitor
Ex Hall Monitor
If it's dieseling it shouldn't be because of the timing because the spark plugs aren't firing with the key off. Dieseling is usually caused by a hot spot in one or more cylinders, often a glowing bit a carbon. Here is a short, simple explanation.
#236827 07/06/2007 6:48 PM
Junior Member
Junior Member
Tiny,
Thanks for the info. Interesting
#236828 07/06/2007 8:24 PM
You may find that it goes away by either:
Replacing the spark plugs
Richening up the idle mixture
Rebuilding the carburator
Adjusting the valves
Running some "Seafoam" or Chem-tool through the tank
Using a plant mister to squirt a small amount of water into the intake when the engine is idling (but not enough to stall the engine)
Paint & Body Shop moderator
#236829 07/06/2007 9:36 PM
Riding in the Passing Lane
Good points. Often it,s just idling too fast.
1972 Chevy c10 Cheyenne Super
#236830 07/07/2007 12:44 AM
You can leave it in gear when you shut if off... but you still need to correct the problem.
Another quality post.
Real Trucks Rattle
