| | | Forums66 Topics128,077 Posts1,056,019 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 8 Junior Member | | Junior Member Joined: Jul 2007 Posts: 8 | So when I'm driving around and come to a stop and turn off the engine it sometimes sputters and makes weird noises even though the ignition is turned off. Is their still gas in the carb? Why is this happening? It does it once in a while but not all the time. Just curious. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | First guess is the timing is off causing the engine to "disel". I'd check it first thing. If that doesn't work let us know and we'll give you reason # 2-25....welcome to the bolt. Great place for questions and answers. | | | | | Joined: Aug 2004 Posts: 47 Member | | Member Joined: Aug 2004 Posts: 47 | For me, this has always been a vacuum leak. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If it's dieseling it shouldn't be because of the timing because the spark plugs aren't firing with the key off. Dieseling is usually caused by a hot spot in one or more cylinders, often a glowing bit a carbon. Here is a short, simple explanation.
| | | | | Joined: Jul 2007 Posts: 8 Junior Member | | Junior Member Joined: Jul 2007 Posts: 8 | Tiny,
Thanks for the info. Interesting | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You may find that it goes away by either: Replacing the spark plugs Richening up the idle mixture Rebuilding the carburator Adjusting the valves Running some "Seafoam" or Chem-tool through the tank Using a plant mister to squirt a small amount of water into the intake when the engine is idling (but not enough to stall the engine)
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Good points. Often it,s just idling too fast. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | You can leave it in gear when you shut if off... but you still need to correct the problem.
