1 members (Shade Baby),
21
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 77 Shop Shark | | Shop Shark Joined: May 2006 Posts: 77 | I plan on switching back to a stok location gas tank (behind the seat). What are the differences between the 48-55 1st and a TF truck? Will the early tank fin into a TF truck? I notice the earlier tank has a bottom feed and the TF tank feeds from the sender assembly. If the earlier tank will fit into a TF truck, I would like to change the feed from 5/16 to 3/8. Also what are the differences in the senders? The previous owner installed a plastic fuel cell under the bed and it fills with water during heavy storms. I'm done with the fuel cell :mad: . TIA
Admin for Turbobuick.com 87 GN, and new toy: 1955 Chevy 3200 pickup, soon to have: 383, Cola crank, Childs/Albert 6 inch rods, Brownfield heads, 10:1 KB hypers, CompCam 284 Extreme Energy, Tilton Plate transmission realignment and built Turbo400.
| | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I can't help you with the main part of your question, but I can tell you that the '48 tank is under the bed, not behind the seat, like later trucks. | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | For some reason I think the earlier (49-54??) feed out the passenger side and the 55+ out the driver side? (as in I don't think they can be swapped at all)
Someone verify this. | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | no they will not fit, the gas line (tank to carb)comes into the bottom a tank a couple of inches in difference from the TF to the AD, and the filler necks are at different heights. i bought a new tank for a 55-59 and found all this out after looking at putting it in my 49. 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: May 2006 Posts: 77 Shop Shark | | Shop Shark Joined: May 2006 Posts: 77 | I now have a 55 2nd series tank, I was going to order a new sender, but the sender fuel line size is 5/16. I noticed that there is a fuel tank drain at the bottom of the tank. Has anyone tried soldering a 6AN fitting to the bottom of the tank and using 3/8 braided hose to the fuel pump? I know the sender hole is the same size as the autometer sender that is used in the JAZ fuel cells, so installing a sender without the pickup tube is not an issue.
