4 members (GrandpasJimmy, SmalltownTRKGuy, Hotrod Lincoln, 1955 1 Series), 115 guests, and 4 robots.
Topics128,194
Posts1,057,248
Members48,466
Apprentice
Apprentice
1 Offline
I have a 56 Chevy pickup with a 79 Camaro drive train. The problem is the axil assembly is to wide (61" drum to drum) to run a wide tire and wheel combo. Anyone know of a GM vehical with a rear axil assembly that is narrower than the camaro with the same 10 bolt pig so I don't have to modify my drive shaft?
Try a V-8 powered Monza. Maybe an S10 pick-up? Someone will be along soon that has actually done such a swap. I'm mainly a "big" truck guy.
Welcome aboard,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Z
Z Offline
the monza and s10 have 7.5" rearends which will be fine if you are running a six cylinder.
My '78 Monte Carlo is 58 inches or close to that. On an AD truck that's narrow enough to make tubbing likely.
1 Offline
why can't you just get some wheels with a lot of backspacing?
2003 ford lightning
1959 chevy 36
Riding in the Passing Lane
It seems to me a nova of that era had the same rear end but was narrower.
1972 Chevy c10 Cheyenne Super
1 Offline
i'll measure my 77 nova when i get home. i plan to use the 10 bolt rear out of it under my 59
2003 ford lightning
1959 chevy 36
Nova and 70-78(?) Camaro rears are interchangeable. Same width, same spring perch spacing.
Cheers,
mark.
