0 members (), 163 guests, and 0 robots.
Topics128,089
Posts1,056,141
Members48,436
#236265 06/27/2007 3:08 AM
Looking for any info on rear gear change for better drivability and gas milage @ lower rpm. any pointers would be greatly appreciated.oh by the way it's for my 58 chevy cameo with 3:90 gear ratio thanks in advance. Big Dave
dave hudson
#236266 06/27/2007 3:11 AM
go to www.randysringandpinion.com and play with their calculaor. it can give your the idea for ratios and tire size and rpms. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#236267 06/27/2007 3:28 AM
THANKS RON I APPRECIATE THE INFO, WILL CHECK IT OUT.
dave hudson
#236268 06/27/2007 3:42 AM
•1952 Chevrolet 3800 pickup
---All pictures---
#236269 06/27/2007 4:28 AM
I also have a 3:90 rear, but I wanted to keep my low end grunt and so opted for a Gear Vendors O.D. It truly gives you the best of both worlds. I work the truck and tow a boat sometimes, so it was a no brainer.
My second choice would be to swap to a T-5.
The only way I would get a higher geared rear is if I didn't drive it much and just wanted to cruise or if I mostly drove on flat freeways.
P.S. I can drive it at 80 mph @ 2800rpm in 4th over. I can also split 3rd and 4th which is perfect for the sm420.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#236270 06/28/2007 12:41 AM
Same here on the OD tranny.I am using a 700R4 OD tranny with my stock 3:90 gears,and a 350 Small block.It performs nicely and it gets me 20 MPG all day long.If ya wanna stick with a 1 to 1 tranny go up to at least a 3:42,or better yet a 3:08 gear.
#236271 06/28/2007 4:27 AM
do a search
i have a T5 w 3.43 rear
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=013926#000000
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=013343;p=1#000002
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=013357#000000
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=013146#000000
Jim & Caroline
#236272 07/02/2007 2:30 AM
thanks for all the advice i really appreciate it.
dave hudson
#236273 07/02/2007 5:36 AM
If you are happy with your present tranny, I would also suggest going to an overdrive. I have a Hone-O-Drive overdrive in my 55 396 powered Cameo that I installed in 1970. I have used it for towing and hauling a camper over most of North America and never had a problem with it. For the longest time, I ran it with a 4:57 rear end but the best combo was with the 3.73 rear end that I am running right now. It took all 350+ hp ( and wide tires :-) ), with no problem, in direct and in overdrive. I will actually be going back to the original 3.90 rear end when I convert back to 2WD, but the truck will still have an overdrive. I need to get my garage built before I redo the truck one more time.
Bob
Bob
55 Cameo 396 TH 400 with overdrive
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
76 GMC 3/4 ton 454ci
84 Buick Turbo Regal
