| | | Forums66 Topics128,087 Posts1,055,980 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 9 New Guy | | New Guy Joined: Apr 2007 Posts: 9 | Looking for any info on rear gear change for better drivability and gas milage @ lower rpm. any pointers would be greatly appreciated.oh by the way it's for my 58 chevy cameo with 3:90 gear ratio thanks in advance. Big Dave
dave hudson
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | go to www.randysringandpinion.com and play with their calculaor. it can give your the idea for ratios and tire size and rpms. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Apr 2007 Posts: 9 New Guy | | New Guy Joined: Apr 2007 Posts: 9 | THANKS RON I APPRECIATE THE INFO, WILL CHECK IT OUT.
dave hudson
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I also have a 3:90 rear, but I wanted to keep my low end grunt and so opted for a Gear Vendors O.D. It truly gives you the best of both worlds. I work the truck and tow a boat sometimes, so it was a no brainer. My second choice would be to swap to a T-5. The only way I would get a higher geared rear is if I didn't drive it much and just wanted to cruise or if I mostly drove on flat freeways. P.S. I can drive it at 80 mph @ 2800rpm in 4th over. I can also split 3rd and 4th which is perfect for the sm420. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Same here on the OD tranny.I am using a 700R4 OD tranny with my stock 3:90 gears,and a 350 Small block.It performs nicely and it gets me 20 MPG all day long.If ya wanna stick with a 1 to 1 tranny go up to at least a 3:42,or better yet a 3:08 gear. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | do a search i have a T5 w 3.43 rear
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=013926#000000
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=013343;p=1#000002
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=013357#000000
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=013146#000000
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Apr 2007 Posts: 9 New Guy | | New Guy Joined: Apr 2007 Posts: 9 | thanks for all the advice i really appreciate it.
dave hudson
| | | | | Joined: Apr 2007 Posts: 147 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 147 | If you are happy with your present tranny, I would also suggest going to an overdrive. I have a Hone-O-Drive overdrive in my 55 396 powered Cameo that I installed in 1970. I have used it for towing and hauling a camper over most of North America and never had a problem with it. For the longest time, I ran it with a 4:57 rear end but the best combo was with the 3.73 rear end that I am running right now. It took all 350+ hp ( and wide tires :-) ), with no problem, in direct and in overdrive. I will actually be going back to the original 3.90 rear end when I convert back to 2WD, but the truck will still have an overdrive. I need to get my garage built before I redo the truck one more time.
Bob
Bob
55 Cameo 396 TH 400 with overdrive 65 Caliente conv 67 BB Caliente conv 67 Mercury 1 Ton 76 GMC 3/4 ton 454ci 84 Buick Turbo Regal
