8 members (KEVINSKI, Gdads51, TexasJim50, 1955 1 Series, Stovebolt48, 32Fordpuchoptop, lumbersawyer, 1 invisible),
59
0
Mod | | | Forums66 Topics128,080 Posts1,055,946 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 10 New Guy | | New Guy Joined: Jun 2007 Posts: 10 | I am working on a 49 truck. I have taken the gas tank out and will replace it as I laid it outside my shop and someone took it. Probably thought it was scrap. It had the fuel line coming out the bottom to the carb. I have heard that some of the replacement tanks do not have this unit in them. What can anyone tell me about this. Do I just use one with fule coming from the sending unit on top. Thanks Dan in Tx
Dan in TX
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Someone correct me if I'm wrong but I believe government regulations require, for safety reasons, the pickup line to exit from the top of the tank. That maybe the only way you can buy a new one now. I may be wrong...
~Jim
| | | | | Joined: Sep 2003 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 181 | I don't think I have ever seen a tank with the outlet anywhere but on the top. I always assumed that was for safety reasons. With the outlet on the bottom, a broken or disconnected fuel line guarantees a major fuel spill. With it on the top, there is still that potential, but at least a siphon effect is required and not mere gravity.
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless! My 1962 Chevy C-30 | | | | | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | 1949 had the fuel line at the bottom of the tank and it DOES guarantee a major fuel spill if the line is broken (or a "drip, drip, drip" if the connection isn't tight). I agree that you may (and probably should) have to buy a a replacement tank with the fuel line at the top. Which means you will not be able to use your stock sending unit. A word of advice is to ALWAYS ask if the threads are metric as a lot of "reproduction" parts come from china.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
| | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | I bought a new tank for my '49 from Chevy Duty and it does have the fuel line exiting the bottom of the tank. The sending unit is in the top but the fuel comes out at the bottom.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | Get one with the baffles and the reservoir in the bottom too... and install an electric fuel pump that "sucks".. and you will be back on the road in no time...
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Rusty, what is a reservoir in the bottom?
~Jim
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | my original tank out of my 51 - 3104 had it's outlet on the BOTTOM. Only the fuel gauge sender was on top w/ NO fuel outlet @ the top. i put a universal tank under the bed see http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=004653#000000 here is a tip on a PRE-FILTER http://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=DSC00312.jpg here is a tip on a PRE-FILTER
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | All ADs with cab mounted tanks had the outlet out of the bottom prior to 1954. My 53 has a shutoff valve just after it leaves the cab bottom. Now, GM made thousands of these trucks this way and I don't think too many burned up because of the bottom outlet. | | | | | Joined: Jun 2007 Posts: 10 New Guy | | New Guy Joined: Jun 2007 Posts: 10 | Thanks to all you guys for this info. It will help me a lot
dan in tx
Dan in TX
