3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#236076 06/23/2007 12:15 AM
I am working on a 49 truck. I have taken the gas tank out and will replace it as I laid it outside my shop and someone took it. Probably thought it was scrap. It had the fuel line coming out the bottom to the carb. I have heard that some of the replacement tanks do not have this unit in them. What can anyone tell me about this. Do I just use one with fule coming from the sending unit on top.
Dan in Tx
Dan in TX
#236077 06/23/2007 3:34 AM
Someone correct me if I'm wrong but I believe government regulations require, for safety reasons, the pickup line to exit from the top of the tank. That maybe the only way you can buy a new one now.
I may be wrong...
~Jim
#236078 06/23/2007 5:45 AM
I don't think I have ever seen a tank with the outlet anywhere but on the top. I always assumed that was for safety reasons. With the outlet on the bottom, a broken or disconnected fuel line guarantees a major fuel spill. With it on the top, there is still that potential, but at least a siphon effect is required and not mere gravity.
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless!
My 1962 Chevy C-30
#236079 06/23/2007 10:50 AM
1949 had the fuel line at the bottom of the tank and it DOES guarantee a major fuel spill if the line is broken (or a "drip, drip, drip" if the connection isn't tight). I agree that you may (and probably should) have to buy a a replacement tank with the fuel line at the top. Which means you will not be able to use your stock sending unit. A word of advice is to ALWAYS ask if the threads are metric as a lot of "reproduction" parts come from china.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#236080 06/23/2007 11:00 AM
I bought a new tank for my '49 from Chevy Duty and it does have the fuel line exiting the bottom of the tank. The sending unit is in the top but the fuel comes out at the bottom.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#236081 06/24/2007 2:16 AM
Get one with the baffles and the reservoir in the bottom too... and install an electric fuel pump that "sucks".. and you will be back on the road in no time...
Another quality post.
Real Trucks Rattle
#236082 06/24/2007 3:52 AM
Rusty, what is a reservoir in the bottom?
~Jim
#236083 06/26/2007 2:11 AM
my original tank out of my 51 - 3104 had it's outlet on the BOTTOM.
Only the fuel gauge sender was on top w/ NO fuel outlet @ the top.
i put a universal tank under the bed
see
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=004653#000000
here is a tip on a PRE-FILTER
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=DSC00312.jpg here is a tip on a PRE-FILTER
Jim & Caroline
#236084 06/26/2007 2:26 AM
All ADs with cab mounted tanks had the outlet out of the bottom prior to 1954. My 53 has a shutoff valve just after it leaves the cab bottom. Now, GM made thousands of these trucks this way and I don't think too many burned up because of the bottom outlet.
#236085 06/26/2007 1:31 PM
Thanks to all you guys for this info. It will help me a lot
dan in tx
Dan in TX
