| | | Forums66 Topics128,036 Posts1,055,460 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 20 Apprentice | | Apprentice Joined: Sep 2005 Posts: 20 | Sorry to ask such a dumb question but here goes. ..Sometimes when I park Lucy(52 1/2 ton)the brake light will come on . I installed a new brake light switch. Even put a piece of rubber hose over the switch arm. Today I shimmed the switch hoping to get the darn thing to turn off. The brake lights work fine when I am driving and apply the brakes. After parking the brake light will stay off for a few minutes and then turn on. I would welcome any ideas. | | | | | Joined: Mar 2007 Posts: 173 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 173 | Is the pedal falling, allowing the switch to come on? If its like my '55 anyways... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no dumb questions here, just solutions to frustrations  prolly your pedal return spring is weak - get things back to factory specs, skip the rubber hose Bill | | | | | Joined: Sep 2005 Posts: 20 Apprentice | | Apprentice Joined: Sep 2005 Posts: 20 | Thanks for the replies. I never thought of a weak return spring. I am going to look into it. With all the talk about how the world is going to h... in a handbasket this site is an example of the basic goodness in people.... People helping people. | | | | | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | I've had that a few times and it was always the switch needing adjustment. Lothar | | | | | Joined: Sep 2003 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 181 | My brake return spring won't even come close to bringing the pedal back up far enough to turn off the brake lights so I have to remember to hook my toe under the pedal and pull it up every time I use the brakes. I have thought about putting a bicycle type 'rattrap' on the pedal. The PO had a screen door closing spring stretched up to the steering column from the pedal arm and I haven't taken it out yet. But even it won't pull the pedal back up.
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless! My 1962 Chevy C-30 | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | You could try and spray some lubricator on the shaft where it atatches to the frame. It has a greese fitting but believe the greese has goten old and sticky causing the peddle not to return to the proper place. | | | | | Joined: Sep 2003 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 181 | I was thinking about trying that, but haven't figured out how to get to it yet. It has been a long time since I looked, but it seems like there was some sort of bulkehead in there blocking my access to it. I'm no metalurgist and am wondering...do springs get weak over time? :confused:
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless! My 1962 Chevy C-30 | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Springs definitely get weak over time. Might try cutting a piece off one end to shorten the length or look for a new spring a bit shorter than what you're using.
As for the switch, does it have elongated holes for adjustment? If not you might try removing the switch and elongate them or elongate further.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Harder to do but you could put an inline switch in.
~Jim
| | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Rusty, Had that exact same problem. I got a spring from the hardware store and hooked it in between the brake pedal and the frame. It may not be right (original speaking) but it works great.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | The brake and clutch pedal have a sleave type bearing that they ride on. This bearing is probably needing to be replaced and or lubed with grease. This will also cause your pedals to drag on the cab floor. | | |
