2 members (Materman, 55shaker), 68 guests, and 1 robot.
Topics128,079
Posts1,055,941
Members48,430
#235244 06/07/2007 12:21 AM
I have a 49 chevy pu and am having a hard time getting the window and regulators out. They both need replacing. Does the window need to come apart from the regulator first.
Look for help
Dan in TX
#235245 06/07/2007 2:05 AM
Dan
The window is attached to the regulator by a channel on the bottom of the window. The arms on the regulator have two round "wheels" of a sort on the end and these roll in the channel.
If I recall correctly once the bolts holding the regulator in place are removed you should be able to slide these "wheels" out of the channel and lift the glass up and out. I believe you should also take the inside window frames off too.
Its been a while since I removed mine but it was quite a simple job compared to the window removal with a vent glass.
I read the shop manual before doing it and it explained it all. If you don't have a shop manual you should get one.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#235246 06/07/2007 2:12 AM
Thanks Bill
I have removed the inside frame and will try this.
Which shop manual do you have. The one I bought is the Chev assembly manual and it is hard to follow.
I have one for my TBIRD that was great so will get one for the 49. Just let me know and again thanks
dan
Dan in TX
#235247 06/07/2007 7:58 PM
Dan, there are four bolts that hold the glass frame to the C-shaped channel olblu49 speaks of. Once you remove the cardboard panel from the door, you can see them through the two openings toward the top of the door, once you roll the window up or down to have the channel meet that level.
Here are the directions as presented in the "servicing Chevrolet Truck Cabs (1947..1948). I'm pretty sure nothing changed for 1949.
"First, remove the control handles and door trim.
Then, raise the door glass and remove the four clutch-head screws which secure the glass frame to the regulator mechanism.
Roll the mechanism down all the way. Then rotate the glass in its opening, as shown, and lift it from the door."
Of course, you can't see the picture, but it shows the latch end of the glass being low in the door, and the leading edge being lifted up.
I'll scan the pages and send them to you, if you'd like to see them. Let me know.
There's nothing in the booklet about removing the regulator.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
#235248 06/08/2007 2:22 AM
Thanks Tom
I finally got them out today. Had to take the whole assembly out as the clutch head screws were rounded out. (of course) Will try to get them out now. THe fun part will be putting it all back
I found what looks like a good repair manual on line and will purchase that
tks
dan
Dan in TX
#235249 06/08/2007 3:35 AM
Dan the service manual I spoke of is the regular 48-53 (I think its those years) Chevrolet Truck Shop Manual. Available at all suppliers. In fact I think there is a link on this site to the various pages which a member so kindly set up.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#235250 06/08/2007 3:39 AM
I could not find the link but I have it under "On-Line Chevy Manuals". You might try to Google it.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#235251 06/08/2007 3:47 PM
Dan, I'm missing those clutch head screws to attach the windows to the channels. Can you give me an idea of what size they are? It's getting near the time for me to to put the doors back together.
1948 Chevy 1/2-Ton
#235252 06/10/2007 2:27 PM
62401
olblu -- the link is listed in the Links Page under "Publications"
But, you can also just click here for the "Old Car Manual Project"
Regards,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
#235253 06/11/2007 6:52 PM
Thanks to all for the help
I ordered a manual and finally got the windows out.I cant wait to try to get them in. Tom I sent you an email and can mail you one of my clutch heads if you want.
dan in Tx
Dan in TX
#235254 06/15/2007 1:40 AM
TOm
Dont know if my reply to you went thru or not
The length of the clutch heads is 5/16 inch
dan
Dan in TX
