7 members (jal12147, F100Ranger, NJC, Bruce 1954-4100, Bill Hanlon, Hotrod Lincoln, 1 invisible),
111
Mod | | | Forums66 Topics128,087 Posts1,056,338 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 13 Junior Member | | Junior Member Joined: Sep 2006 Posts: 13 | All I have installed a power steering conversion kit on my 1953 GMC 1/2 ton pick up and after getting it all installed and plumbed and filled I started the truck and let it bleed the air out then topped it off. I started the truck back up and tried to turn the wheel I had some resistance at first then it let go and all seemed to work well, Then I looked under the truck and saw a puddle the steering box is leaking at the input shaft. I removed the jam nut and the nut to repair the seal put it back together but it still leaks.
Any suggestions? CPP told me they would sell me a new steering box, but I don't want to yet.
Evan | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | Evan, Check to see that you don't have the pressure & return hoses crossed. There are other places to buy exchange steering boxes besides CPP. Fred
| | | | | Joined: Sep 2006 Posts: 13 Junior Member | | Junior Member Joined: Sep 2006 Posts: 13 | Thanks Fred I have verified that the hoses are correct, and I can get a box from Advance Auto Parts for $159.00. What I ment was CPP seemed more interested in selling me new parts rather than giving me clear reasoning as to why the leak is at the input shaft.
I think I will get another box from the salvage yard. | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | Evan, I'm not so sure CPP would be selling you a "new" box, like most of the aftermarket suppliers it is likely a reconditioned unit with the core charge included in the price. They don't have a shop or install this stuff so the technical level is somewhat limited. Fred
