1 members (UtahYork),
128
Mod | | | Forums66 Topics128,186 Posts1,057,318 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | Need some advice about putting a Chevy S-10 chassis under a 46 1/2 ton short bed pickup.
I will be using 350 SBC with a th400 transmission.
I would like to know some of the problems. I think I am going to cut the 46 frame in front of and behind the cab. I will use the front and rear parts of the S-10 frame and suspensions.
Does anyone have experience with this idea?
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Frank,
The only conversions I have seen on here use the whole S-10 frame. As I recall, the wheel base is about right. All you need to do is make brackets to support everything.
After having my 46 down to the frame, I don't know that the section you are leaving helps you enough to make it worth keeping. My $.02 would be to keep the S-10 frame in one piece and use as is. Keep the 46 frame in one piece and use it to determine what needs to go where etc.
Also, use the search function above...there should be quite a number of topics on here regarding S-10 swaps. | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | 46in progress, thanks, after a little research I've decided to keep the s-10 frame intact. This is going to be exciting. LOL
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | Hope you will take lots of pictures and keep us up to date ! Ter | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | Do worry about that. I've done alot of research and only found one item that discussed it. The photos were pretty good, but.....
So I plan on documenting the build.
Frank
