6 members (Stovebolt48, cmayna, Gone, Rusty Rod, Gdads51, 1 invisible), 83 guests, and 3 robots.
Topics128,187
Posts1,057,312
Members48,468
Need some advice about putting a Chevy S-10 chassis under a 46 1/2 ton short bed pickup.
I will be using 350 SBC with a th400 transmission.
I would like to know some of the problems. I think I am going to cut the 46 frame in front of and behind the cab. I will use the front and rear parts of the S-10 frame and suspensions.
Does anyone have experience with this idea?
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now.
http://www.coxcustomcars.com/
Frank,
The only conversions I have seen on here use the whole S-10 frame. As I recall, the wheel base is about right. All you need to do is make brackets to support everything.
After having my 46 down to the frame, I don't know that the section you are leaving helps you enough to make it worth keeping. My $.02 would be to keep the S-10 frame in one piece and use as is. Keep the 46 frame in one piece and use it to determine what needs to go where etc.
Also, use the search function above...there should be quite a number of topics on here regarding S-10 swaps.
46in progress, thanks, after a little research I've decided to keep the s-10 frame intact. This is going to be exciting. LOL
Ter Offline
Hope you will take lots of pictures and keep us up to date !
Ter
Do worry about that. I've done alot of research and only found one item that discussed it. The photos were pretty good, but.....
So I plan on documenting the build.
Frank
there are kits available, dont know about your model though. comes with the brackets you need. check it out here
http://www.ad-engineering.com/KitComponents.html
