| | | Forums66 Topics128,185 Posts1,057,279 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 45 Junior Member | | Junior Member Joined: Aug 2004 Posts: 45 | Got a 66 chev 1/2 and found a 87 suburban will all the upper and lower arm swaps work including booster, master cylinder etc. Also thinking about using the power steering setup. A couple of guys said it would be but i wanted to be more sure than not before i fork out the cash. thanks | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | My stuff all came from a 1980, get it all,,Brian | | | | | Joined: Aug 2004 Posts: 45 Junior Member | | Junior Member Joined: Aug 2004 Posts: 45 | | | | | | Joined: Feb 2007 Posts: 8 Junior Member | | Junior Member Joined: Feb 2007 Posts: 8 | I sure hope it works, because I have the same combination waiting to install. I tried asking this before but didn't get any reply.
I read somewhere here about someone doing something like it. The issue seems to be the difference in frame widths, with the older being narrower by an inch.
I want to swap as much as possible, steering, booster, plumbing, motor mounts, motor, trans, etc. I was going to cut the frame and swap the whole front. Someone in the education part here has a step by step.
Go ahead and do it, then tell me what to do different : ) | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Don'c cut the frame, the front crossmember unbolts w/about 14 bolts & the later bolts up, although a couple holes may need reemed. The steering gear bolts up after drilling a coupla holes using a REZ Engineering kit. | | | | | Joined: Aug 2004 Posts: 45 Junior Member | | Junior Member Joined: Aug 2004 Posts: 45 | My truck already has a 350 in it with a 350 turbo tranny so i for sure don't want to have to repull the engine. More less looking to take the upper/lower controls arms including spindles, rotors etc and move them over to the 66. Also put the brake booster including master cylinder also. I heard it will pretty much bolt up as it was made for it, but by looking at the arms on the suburban they look more massive i haven't had a chance to measure yet. The guy wants me to buy the whole truck but when you live in a subdivision i am sure the home owners association would love that one. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | You can support the engine from the top & won't have to pull it out, or you should be able to swap just the arms also. | | | | | Joined: Feb 2002 Posts: 2,896 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,896 | this guy used the stuff from a '83 suburban in his 1966 c20: http://www.persh.org/pickup/pickup-beginning.htm He has several articles on how he did some of it. He even used the REZ kit that 64Fleetside mentioned: http://www.persh.org/pickup/steering.htm Check it out. Here is a tech article from one of the truck magazines, using the same kit: Tech Articles Power Steering Retrofit - Make Your Classic Truck More Driveable Adding Power Steering By Bob Carpenter http://www.customclassictrucks.com/techarticles/60_66_chevy_gmc_power_steering_retrofit/ enjoy, -W several vendors sell the kit from REZ, but this is their information: REZ Engineering - No website yet, call or write - power steering kit. used trucks to part out(particularly 4x4). 1960 - 1966 Chevy/GMC. - PO Box 1584 - Great Falls, Montana 59405 Ph. 406-727-9267 | | | | | Joined: Aug 2004 Posts: 45 Junior Member | | Junior Member Joined: Aug 2004 Posts: 45 | Thanks woogeroo and all who posted. | | |
