1 members (Hotrod Lincoln), 79 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#233841 05/13/2007 12:59 AM
i have been looking at different grilles on some of the other trucks posted on this site and have realized that they are different from mine. here are the best pics i have of it, i'll try to get some better ones if needed.
http://good-times.webshots.com/album/558976599EVaWGw
a little history might help, i saw it advertised as a 1949 gmc truck, after i got it home i ran the vin on the cab and found it to be a 51, i think.
heres the vin, 1931410711.
i havent found a matching pic of a grille yet. i have seen signal lights in the top corner of the grille, but not in mine, only on the fenders below the headlights. so i have a 51 cab ( i think ) but need help with the front clip. thanks!!
#233842 05/13/2007 1:27 AM
If the doors are original to the truck, it's a '51 (vent window with turn down door handles). As far as the grill, the GMC grill is pretty much the same up to '53. The turn signals are below the headlamps on GMC, http://www.stovebolt.com/gallery/english_rob_1951_01.htm , in the grill corners on a Chevy,
http://www.stovebolt.com/gallery/mccormick_jim_1951.htm
I hope this helps you out.
Bill Burmeister
#233843 05/13/2007 1:41 AM
thats great! i was wondering what the difference was i didnt know the grilles were diffrent between the chev and gmc. but now that i see it, kinda makes sense.
thanks bill!
#233844 05/13/2007 2:51 AM
The grills changed on the GMC in 1949. Previous to that they were a three bar grill and they were a different width with an entirely different mounting. You can see my grill on my webshots and it is the same shape as yours.
1951 1 Ton Completed
